Hello Guest it is November 11, 2026, 04:31:36 PM
Author Topic: Dual Axis homing  (Read 18162 times)
Dual Axis homing
« on: July 01, 2012, 09:03:20 AM »
Hello
I try a gantry milling machine with a dual X axis (C slave) to homing.
All axis has its own reference switches. Z and Y works well.
With the hook "Home with Master Slave Axis" will stop the X axis and moves the switch again free. (C Slave the same)
Without active "Home with Master Axis" adjusted the slave axis, but the X axis run over the reference switch.
Mach3R3.043.058W-33
PlugIn: SmoothStepper_v17f
Attached is the xml
How I have to set does the homing also works with the slave?
Regards
Philipp
Re: Dual Axis homing
« Reply #1 on: July 01, 2012, 11:50:52 AM »
Would you not be wanting to home the slave with the master anyway?
Its likely a SS issue if its not working right as homing is handled in the SS rather than in Mach.
« Reply #2 on: July 01, 2012, 12:49:09 PM »
Hi Hood
To align the gantry, (synchronise the two Axis) I have to disable "Home Slave with Master Axis" ?
It's run with the newest Plug in  :-\
 In the register "Homing/Limits" is a column with "Home Off." but with this values it's changed nothing.
I would like to going a little away from the limitswitch.
Philipp
« Reply #3 on: July 01, 2012, 02:33:22 PM »
Ok I thought that was what it was doing when you said
"With the hook "Home with Master Slave Axis" will stop the X axis and moves the switch again free. (C Slave the same)"
Home Off is not to set a distance to move off the switch, it is there so you can enter a value if you home switches are not at Machine zero.
« Reply #4 on: July 01, 2012, 03:39:59 PM »
Hi Hood
Without the hook:
1. Z move up, Z switch, chang the direction move to switch OK (closed)  :)
2. Y move to -Y, Y switch, change direction  and move to the switch is ok  :)
3. X and C move to -X, X switch , both change the direction and move to switch X OK.   ???
        C is not checked the switch.
with the hook:   (1 and 2 are the same)
3. X and C move to -X, X switch , X change the direction and move to switch X OK and immediately again -X over the limitswitch    ???
4.                             C switch , C Axis change the direction and move to the switch is ok.   :)
Anything in part 3 going wrong!
Philipp
« Reply #5 on: July 01, 2012, 03:59:43 PM »
Ok I see what you are saying now. Probably best to look on the warp9 forum as I know there have been issues with slaved homing in the past.
« Reply #6 on: July 01, 2012, 04:30:12 PM »
I don't know what the SS does, but with the parallel port, when you check "Home Slave with Master", the slave axis switch is not used.
« Reply #7 on: July 08, 2012, 03:51:46 AM »
Hi
Yesterday we tested again and we saw, it was the old mach3 version still installed. We deinstalld and deleted all mach 3 programs and folders. and install the newest mach3 version with the ss plugin V17f.
Now it works fine. sorry about the confusion.
Regards Philipp
