Hello Guest it is October 11, 2026, 06:27:43 AM
Author Topic: Z axis problem  (Read 9008 times)
Z axis problem
« on: June 30, 2012, 10:00:51 AM »
Hi All, I have been using Mach 3 for a few years without any problems until now.
I was setting the motor turning for my new stepper motor on the z axis ( it is the same motor as on the X & Y axis) the first run went fine but the distance moved was wrong so I did another run and this is when it all went wrong.
When I hit run the motor moved but it never stopped until it hit the E stop and I had set it to move 20mm. I went  back to program mode and tried the movement on the Z axisi to find the motor moved as normal but no reading as to the position.
I have checked all settings and cannot find anything wrong, accept for when running the diagnostic screen  where it shows "output current state for port 1 has only two green lights showing and I am assuming that there should be three one for each axis ?
I may well be missing something obvious but I cannot find anywhere to put this right.
Any ideas to solve this would be much appreciated.
Re: Z axis problem
« Reply #1 on: June 30, 2012, 11:11:09 AM »
Attach your xml and I will have a look.
Re: Z axis problem
« Reply #2 on: July 01, 2012, 04:37:48 AM »
Hi Hood, I have sorted it, I went to operator section then restore settings and that did the trick.
Somewhere down the line I must have pressed the wrong button to cause my problem.
Thanks again
Ray
