Hello Guest it is November 11, 2026, 07:14:46 PM
Author Topic: SS not allowing config  (Read 11675 times)
« on: June 29, 2012, 10:45:12 AM »
We have been running the SS with Mach3 with all latest releases for several
weeks now. When we try to access the Plugin configuration, the drop down menu
only shows "-". I've had this happen on other machines also. I'm using a custom
Mach3 screen that I made. If I reinstall and use a standard Mach3 screen, the
drop down works fine. Is there a setting I have set wrong or what? I need to change
something in the config screen but cant get there.
Tbyrd
Re: SS not allowing config
« Reply #1 on: June 30, 2012, 10:23:02 AM »
There is no setting I can think of that would affect that, it must be something to do with your screenset. If you want to attach your screenset and its associated bitmaps I will have a look and see if I can find the problem.
In the mean time you could change to the standard screen, change the settings in SS Config then change back to your own screenset.
« Reply #2 on: July 05, 2012, 03:14:24 PM »
I discovered that even though I have a button on my screen to turn on menus, ( I have them turned off normally through the general config screen) it doesn't turn on all the menus. You have to go to the general config screen and turn them on, then restart mach3. No problem, I just had to find that out.
Tbyrd
