Hello Guest it is November 17, 2026, 11:33:52 PM
Author Topic: PWM Spindle Output Problem  (Read 7283 times)
Offline SScnc
  •  77 77
« on: June 28, 2012, 09:06:19 PM »
I'm using the Digispeed XL from Homann Designs with a GS3 AutomationDirect VFD and a 3600RPM motor, and I'm having a small problem. The spindle operates as expected, however the speed is not correct. I have a high and low speed. I've set the pulleys up, which the ratio box seems to have no effect on the PWM output. For instance my low speed is a max of 2000 and when I enter M3 S2000 the VFD is only running around 40hz or approx 2400 motor speed.
I'm not sure what exactly I need to adjust? Or what I'm missing here.
Any help is appreciated.
