Hello Guest it is November 24, 2026, 02:12:03 AM
Author Topic: Gcode -using a period in parameters  (Read 8510 times)
« on: June 25, 2012, 10:21:25 AM »
Hello There all of you
I am writing a program which will output gcode for simple machining
If I am using a parameter as say for instance
#11=30.5    ( where 30.5 is a dimension for roughing out)
Is it allowable to use a period within the paramater for instance
#11.1= 30.0 ( where 30.0 is the finished size)
many thanks
fred evans
Re: Gcode -using a period in parameters
« Reply #1 on: June 25, 2012, 10:55:12 AM »
NO all #var names MUST be integers.
