Hello Guest it is October 01, 2026, 04:37:57 AM
Author Topic: G92 does not always take.. why??  (Read 70309 times)
Offline nicad
  •  40 40
« on: February 05, 2006, 04:56:47 PM »
I have observed this problem in Mach 2 6.11 and now just happened to me today with Mach3.
G92 command randomly gets ignored. G92 should change the designated axis to the value given (no movement).
Example:
G0 Z1
G92 Z0
Most of the time Z will be 0 after this, but sometimes, randomly, Z will still be 1.
why??
Art
Re: G92 does not always take.. why??
« Reply #1 on: February 05, 2006, 05:47:33 PM »
Hi:
 I havent observed this one. Is it mixed with another ocde on the line, an erronous line can be ignored.. (Thoguh it shoudl give an error..)
Art
Offline nicad
  •  40 40
« Reply #2 on: February 05, 2006, 11:46:05 PM »
Art-
Nope- always on its own line.
It works most of the time.. but every now and then it won't. same code, just random.
here is a segment of the exact code (beginning of the program) where it happened today:
Code: [Select]
G40G49G80G64G90
G0 Z1.5
X0.125 Y0 Z0.86
G1 X-1.2 A2520 F90
A2880
G92 A0
X-0.0059 F80
After this, A may still be 2880, or it may be 0.
If I run it step-by-step mode, it will always work correctly.
When running through normally is when it might ignore it.
I have also had this happen in the past on a Y axis re-setting to 0 (in Mach2 V6.11)
Any ideas?? :)
Art
« Reply #3 on: February 06, 2006, 06:27:15 AM »
Make sure in Config/state that you dont have "Shortest Rot." checked. A2880 IS A0, so it could see that as zero since 28880 is a multiple of 360 or 0.
 Cant think of anythign else that coudl do it..
