Hello Guest it is November 04, 2026, 01:22:21 AM
Author Topic: X-Y offset in tool change? Macro?  (Read 13675 times)
« on: June 23, 2012, 02:19:29 PM »
Brainstorming here,...
The cost of a tool changer is way expensive.
I cut mainly cabinet parts. I use 3 tools, a 3/8" for cutting, 8mm for dowel holes, 5mm for system holes.
Besides my main spindle that holds the 3/8" bit, I'm thinking of adding 2 smaller spindles for drilling the 8mm and 5mm holes.
My quest would now be;
- When I do a tool change, I need to select 1 of these 3 spindles and make this the only Z-axis to move.
- At the same time, besides the z-offset, I now also need the x and y offset changed, this should be calibrated once and stored.
I suppose this could be done using a custom g-code builder that "considers" these offsets. Better would be do have Mach3 store the offsets and make it happen automatically. But Mach3 only allows for z-offsets. Could a Mach3 macro cover this?
Stefan V
Re: X-Y offset in tool change? Macro?
« Reply #1 on: June 23, 2012, 02:38:50 PM »
G54-G59 fixture offsets will do exactly what you need.
« Reply #2 on: June 23, 2012, 05:51:23 PM »
I think you might be better off using G52 offsets, in a macropump which automatically does the offsets based on the current tool #. Just make sure you use a unique too # for the 5mm & 8mm tools. Or use it in an M6 macro when the tools are changed.
Something like this.
tool = GetSelectedTool()
if tool=1 then
code"G52 x0 y0 z0"
end if
if tool=2 then
code"G52 x10 y0 z0"
end if
« Reply #3 on: June 23, 2012, 08:05:47 PM »
Anyone out there that uses a similar system? It is not make multiples of the same part using an offset, but using different spindles to work on the same part.
I have another CNC with a tool changer, so I hope to be able to use the same g-code. So the whole procedure of switching spindles and automatically changing the XYZ offset should be triggered by one simple tool change command. I figure that a decent tool changer can't be found for less than 5K, an extra spindle for boring only, can be build for a few hundred.
Stefan V
« Reply #4 on: June 23, 2012, 08:58:51 PM »
Stefan V
You've been given two very simple ways of doing what you need.  What more are you looking for??
« Reply #5 on: June 23, 2012, 09:03:48 PM »
The code I posted above is a sample from someone on the Yahoo group who has a machine with 37 spindles.
So yes, someone is doing exactly what I posted.
