Hello Guest it is November 07, 2026, 02:08:35 AM
Author Topic: DrilMasterV1.01  (Read 55400 times)
Re: DrilMasterV1.01
« Reply #10 on: June 22, 2012, 07:12:46 PM »
TP,
Looks good. Why not just have the three drill cylces like the mill one has?
Can you add Dwell under safe Z.?
With real small drills ( #80 to #90) I feed the drill  just a few thou at a very slow feedrate and then let it  "dwell"  on the surface for a time period, maybe as long as 5 or 10 seconds. Once the drill has cut into the material , similar to spot drilling it, your ready to do a drill cycle. Example, Z=.003,Q=.003,R=0,F=.02 but the drill dwells at the surface for a time period "before" the Z move. Normaly I do this using my MPG and watching the drill under a microscope and then use a peck drilling cycle.
Re: DrilMasterV1.01
« Reply #11 on: June 23, 2012, 10:17:22 AM »
That's pretty neat. Thanks TP!
Re: DrilMasterV1.01
« Reply #12 on: June 23, 2012, 01:42:02 PM »
Rich THAT is the reason I asked about doing it in Mill mode rather than Turn. In Mill mode you have the full DEPENDABLE  USE of ALL the drill cycles NO so much in turn. (;-)
Piece of cake in MIll mode.
(;-)TP
Re: DrilMasterV1.01
« Reply #13 on: June 23, 2012, 03:11:33 PM »
Rich do the Normal drill cycles even work in TURN or do I not understand the Canned cycle FUnctions in turn??
I don't use turn much(;-), (;-) TP
Re: DrilMasterV1.01
« Reply #14 on: June 23, 2012, 03:38:24 PM »
RIch here is the new screen . IF is is usefully I can recode the buttons to work correctly. IF I can figure out the TURN canned drill cycles (;-) (they do not work here for me)
I can tell you for sure IF you are not spot drilling the small holes your machine may eat the bits in auto mode AS there is no provision for a top spotting dwell (;-) and your tiny bits will either brake or start off center.
Been there as well, (;-) TP
« Last Edit: June 23, 2012, 03:41:07 PM by BR549 »
Re: DrilMasterV1.01
« Reply #15 on: June 25, 2012, 05:21:13 AM »
Terry,
I need to do some testing,hopefully it will be this week ( time has not been my owne for a couple of months ) and will get back to you with answers.
Till then and thanks,
