Hello Guest it is November 22, 2026, 07:06:43 AM
Author Topic: Basic tool use  (Read 12736 times)
Basic tool use
« on: January 13, 2007, 08:09:16 AM »
Hello Everyone,
I am just getting started with CNC and could use some help.  I am using TurboCadCam to generate G-code to feed Mach3 which will drive my ShopTask mill/lathe.  At this point the hardware is working and I have my motors reasonably close.  Now that I can move the table about in a predictable pattern and speed it is almost time to start cutting something.
I am having some difficulty with the Mach3 tool configuration.
I opened the Config | ToolTable dialog and saved tool 1 as:
      Description:     End Mill, 2 flute
      Diameter:        0.2500
      Height:           0.5000
But I haven't been able to figure out how to load tool 1 or tell Mach3 that tool 1 is loaded.  That is to say the Mach3 tool displays are always zero.
What have I missed?
Bob
Re: Basic tool use
« Reply #1 on: January 13, 2007, 08:13:12 AM »
Bob to use tool length offsets you will need to have a G43 H1
This will load tool offset 1 and if you would like more info a good start is the Mach3 manual. and ifyou have more questions please feel free :)
www.newfangledsolutions.com
www.machsupport.com
Re: Basic tool use
« Reply #2 on: January 13, 2007, 09:00:02 AM »
Hello Brian,
I tried entering G43 H1 on the MDI screen, but the  only thing that changed was the Z axis.
What I am looking for is the process that changes the default Tool number zero with a diameter and height of zero to my preferred selection of tool 1 with a diameter of 0.25.
If you of anyone else can point me to where this is addressed in the users manual, I would be very grateful.
Bob
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Basic tool use
« Reply #3 on: January 13, 2007, 10:08:07 AM »
Enter G43 T1 H1 M6 in mdi and that should do it.
Graham.
Re: Basic tool use
« Reply #4 on: January 13, 2007, 11:32:10 AM »
Hi Graham,
Thank you!  That was the key I was looking for...
For those who may follow...
The T (tool) command is described in section 10.10.3 of the "Using Mach3 Mill" manual.
Search for "Select Tool".
Bob  :) :) :)
