Hello Guest it is November 13, 2026, 10:00:44 PM
Author Topic: Writing a Gcode  (Read 9681 times)
Writing a Gcode
« on: June 20, 2012, 02:24:58 AM »
I am trying to write a gcode/mcode sequence to do the following:
1. Run a motor on X axis until it hits a limit switch and stops (I'm using a limit switch input on a breakout board to operate an optical sensor).
2. Then dwell for 2 seconds and then activate a relay on Y output for 2 - 3 milliseconds then dwell for 2 seconds.
3. Then activate a relay on Z output for 2 - 3 milliseconds then dwell for 2 seconds and then repeat the procedure again.
Can anyone help as I'm new to the whole Mach3 scene and would appreciate any help.
Re: Writing a Gcode
« Reply #1 on: June 20, 2012, 10:22:12 AM »
You are going to find out that MACH3 does NOT have precise time delay control on inputs or outputs.
Re: Writing a Gcode
« Reply #2 on: June 23, 2012, 09:09:00 PM »
 BR549
He may be able to use a macro where a pause command is timed in msecs.
Just a thought,
I LAWR YN Y CYMOEDD
Re: Writing a Gcode
« Reply #3 on: June 24, 2012, 11:10:56 AM »
Mach3 does not always abide by the input Msec loop values (;-) .
Been there done that , (;-) TP
