Hello Guest it is October 21, 2026, 03:46:22 AM
Author Topic: Mach 3 resetting the screen and configs by itself  (Read 13116 times)
« on: June 18, 2012, 01:34:08 PM »
Hello guyz, I'm facing this odd problem with Mach 3. Everything works perfect then someday when I turn on the PC all my configs are gone including the screen. I was wondering what could make the Mach 3 restore to the original config?
Thank you
Re: Mach 3 resetting the screen and configs by itself
« Reply #1 on: June 18, 2012, 01:53:00 PM »
Your config is held in your xml for the profile you use so unless that gets deleted you should not lose your settings.
Only way I could see something like that happening is if you have some sort of auto restore function set in windows.
« Reply #2 on: June 18, 2012, 02:26:31 PM »
I don't have any auto restore function in my Windows, as far as I know.
The thing is I have the backup of my XML folder and when this happens I copy and paste and everything is ok.
I just like to know if someone has already experienced this problem. Maybe is something from Windows 7.
« Reply #3 on: June 20, 2012, 08:21:42 AM »
Any other suggestion?
« Reply #4 on: June 20, 2012, 08:32:06 AM »
there is something odd about the way or place windows 7 stores the xml, i can't remember off hand where or what happens but someone else may be more aware of this. Try searching for copies or looking for strange directories.
« Reply #5 on: June 20, 2012, 08:53:35 AM »
Someone told me that shutting down the computer without closing the Mach 3 may cause this problem.
« Reply #6 on: June 20, 2012, 08:54:38 AM »
you have to close mach for the xml changes to be saved
« Reply #7 on: June 20, 2012, 08:55:09 AM »
that's sop for most programs.
