Hello Guest it is November 10, 2026, 01:54:57 AM
Author Topic: EStop and Nested Loops  (Read 6847 times)
« on: June 16, 2012, 06:12:27 PM »
Is there a better way to handle EStops in a nested loop?  I need to stop the loops from running if the EStop is pressed.  If I dont once the machine is returned to safe mode the Nested Loop continues to run.
Here is my VB Code:
Sub Main
If IsEStop() Then
    Print ("Estop")
    Exit Sub
Else
For r = 1 to 3
If IsEStop() Then
    Print ("Estop")
    Exit Sub
Else
Print "r=" & r
End If
For i = 1 to 10
If IsEStop() Then
    Print ("Estop")
    Exit Sub
Else
Print "i=" & i
End If
Next i
Next r
End If
End Sub
Re: EStop and Nested Loops
« Reply #1 on: June 19, 2012, 04:51:10 PM »
That is a very good question. I see your point but don't have a solution.
I will ask around, (;-) TP
