Hello Guest it is November 23, 2026, 12:19:37 AM
Author Topic: Alternative Feedrate OEM codes - do they work?  (Read 14288 times)
« on: June 13, 2012, 11:39:53 AM »
I found these OEM Codes:
OEM LED 113           Alternative feedrate in use (see OEM DRO 122) LED
OEM Button 299       Toggle bypass feed (enables value in OEM DRO 122)
OEM DRO 122          Feed rate ignoring that set in F word DRO
I added a button to my screen but it doesn't seem to work. The OEM LED works, and seems to indicate the alternate feedrate is active, but it doesn't change the feedrate.
Is anybody familiar with this feature?
« Last Edit: June 13, 2012, 11:42:01 AM by 2000mph »
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." Antoine de Saint-Exupery (1900 - 1944)
Re: Alternative Feedrate OEM codes - do they work?
« Reply #1 on: June 13, 2012, 01:25:52 PM »
Yes They still work "Here"
It is a form of FRO
The dro is a multiplier of the feedrate. If your FR is 10 and the DRO input is 10 then the new feedrate is 100. (10x10)
The toggle button turns it on and off.
« Reply #2 on: June 13, 2012, 08:53:18 PM »
Thanks for the explanation TP. ;)
I tried it on my machine and it has zero effect, even though the LED indicates it is active.
I don't get why you say:
with quotation marks around the word "Here".  ???
Am I missing something?
« Reply #3 on: June 13, 2012, 10:46:37 PM »
Over the years there have been a LOT of things that I can get to work HERE on my setup that does NOT always work elsewhere on THEIR Machines.
IF you setup a button an LED and a DRO to drive the function it SHOULD work for you.  Input the multiplier for the FRO then press the button and the LED should come ON and the current feedrate should be multiplied by the DRO value. AND you should see the increase on the main screen .
« Reply #4 on: June 14, 2012, 01:17:56 AM »
Aaahh.... now I understand. It seems this is another one of those times. :(
I have done just as you instruct. The LED comes on, but no change in feedrate....
Thanks TP!
« Reply #5 on: June 14, 2012, 02:57:18 AM »
I am new so may be way off the mark but using my pendant I could alter the FRO slider but no change in feed rate UNTIL I unchecked (No FRO on Queue ) in Config >General config  ;) wonder if this may help
Regards
Nick
« Reply #6 on: June 14, 2012, 10:38:32 AM »
Just tried it again here IT still works "HERE"  (;-) V.062
« Reply #7 on: June 14, 2012, 11:59:36 AM »
Thanks Nick,
But "No FRO on Queue" is already unchecked. :(
TP,
Thanks for confirming it works for you.... ;)
I have Ver 3.043.022. I thought it was the lockdown version. I'll look into upgrading.
« Last Edit: June 14, 2012, 12:04:08 PM by 2000mph »
