Hello Guest it is November 22, 2026, 02:27:59 PM
Author Topic: can not edit g-code in mach3  (Read 9227 times)
« on: June 12, 2012, 02:02:30 PM »
hi, hope i am posting in the correct spot .
i am using cambam to write programs from dxf . it all work good for what i am using it for . the problem i have ran into is that after loading the cambam file into mach3 i can not edit the gcode from the mach3 screen . any help would be great . thanks
Re: can not edit g-code in mach3
« Reply #1 on: June 12, 2012, 04:57:08 PM »
Do you have an editor assigned in General Config?
