Hello Guest it is November 03, 2026, 10:34:57 PM
Author Topic: Mach 3 Spindle Problem  (Read 12562 times)
« on: June 11, 2012, 09:11:01 PM »
Hi guys,
I really need your help. I have a K2CNC router with a simple on/off relay. I have the right parameters set. I can turn the spindle on and off with the Mach 3 spindle on switch no problem. But when I MDI in M3 or run M3 in a program it does not work! Help!
Re: Mach 3 Spindle Problem
« Reply #1 on: June 13, 2012, 09:23:02 PM »
Anyone?
« Reply #2 on: June 14, 2012, 02:03:10 AM »
Attach your xml and I will have a look at the config.
« Reply #3 on: June 14, 2012, 02:47:14 AM »
Thank you, mate! This is the original profile sent to me. What I did to get the mach 3 software spindle on button to work was to change the ports and pins spindle setup m3 m4 outputs from 2 & 1 to 1 & 2.
« Reply #4 on: June 14, 2012, 03:03:50 AM »
Will need your xml, no point in looking at one that you are not using.
« Reply #5 on: June 15, 2012, 09:14:19 PM »
i to am in the same situation. talk to the guy who built and set it up and we are at a dead end. thinking of doing an uninstall and reinstall of mach to see if that will work.kinda frustrating.
« Reply #6 on: June 22, 2012, 06:22:29 PM »
It may need an "s" word. Spindle speed. Try something like:
M3 S30000
