Hello Guest it is November 25, 2026, 12:09:43 AM
Author Topic: Need help can i flip the code design  (Read 11317 times)
« on: June 10, 2012, 04:55:06 PM »
Hi
I am designing things in V Carve and it it a pain in the butt to design something and then have to flip it all to cut on my CNC th see id side ways and have to re-line everything.
It is designed sideways but it can to cut in my cnc that way.
Can i do this in Mach 3 after i load in the code for the design some how?
My cnc cuts 20 wide by 30 long and my designs are 24 long by 7 to 10 tall so they need to be fliped to be able to cut down the 30 inch side of the cnc.
Can i load in the design code and just click on something in Mach3 to rotate the design before cutting it.
Re: Need help can i flip the code design
« Reply #1 on: June 10, 2012, 05:12:09 PM »
A quick solution may be to swap the plug for the X and y axis motors on the controller, assuming that the leadscrews are the same.
Alternatively, go into Maxh3 and swap the pin assignments for the two axis.  Make the long axis X and the short axis Y
Cheers,
Peter
Homann Designs
http://www.homanndesigns.com
« Reply #2 on: June 10, 2012, 06:09:47 PM »
How do i
I am not sure what to do and in what place ???
  •  9,378 9,378
« Reply #3 on: June 11, 2012, 01:56:01 AM »
Hi Eddie,
On the Mach3 'MDI' page see 'Local System Rotated'
« Reply #4 on: June 24, 2012, 06:22:59 PM »
Ok i think i got it - i set it to 90 and then did a test run not cutting but it looked like that will work as it ran the long way.
