Hello Guest it is November 22, 2026, 02:25:46 PM
Author Topic: CamBam?  (Read 14036 times)
CamBam?
« on: June 08, 2012, 10:26:58 PM »
I just got a tele guitar body drawing in ".dwg"     It will not open in CamBam. Is dwg not for CamBam?
Re: CamBam?
« Reply #1 on: June 08, 2012, 10:51:09 PM »
DWG is for autocad  what you are looking for is DXF. Anyone with Acad can convert it to DXF for you.
Re: CamBam?
« Reply #2 on: June 09, 2012, 11:39:43 AM »
Cool Thanks! I am loving this stuff I have been researching for days straight! lol I am going to get this! Its all very simply complicated. Got another question. If I bought a CAD program I could convert stuff like this myself right? Also if I draw something in CAD can I use it on mach 3 of does it have to go through a CAM software first to creat toolpaths and all that? if so for starting out. I was thinking turboCAD cause its only $99 and then what CAM for around the same? I just want something to get me up and running without having to spend an arm! I just want something that would work, something I can draw up and cut it out. Mainly wood for now.
Re: CamBam?
« Reply #3 on: June 09, 2012, 11:41:21 AM »
I just noticed you said specifically "AutoCAD"  is it strictly Autocad that uses this type and can convert or will any CAD work?
Re: CamBam?
« Reply #4 on: June 09, 2012, 12:59:28 PM »
SOme will some won't. IF you are looking for a free acad clone program try the free version of progecad. It can read native DWG and ouput in DXF
You draw in CAD then convert to Gcode in CAM
Re: CamBam?
« Reply #5 on: June 09, 2012, 01:01:12 PM »
Try Draftsight, it's free and should be able to save that as a .dxf.
Also, you can try A9 Converter, which is free, and can convert .dwg files to .dxf files. www.A9tech.com
Edit:
There sight seems to be down, but you can get it here.
http://www.activedwg.com/Downloads/A9ConverterSetup.exe
Re: CamBam?
« Reply #6 on: June 09, 2012, 01:41:08 PM »
Man you guys are great! Thanks a million! ;D
