Hello Guest it is November 22, 2026, 08:12:59 PM
Author Topic: CV Mode turns off by its self  (Read 12673 times)
« on: June 02, 2012, 10:27:10 AM »
Hello all, I have a problem with my CV Mode turning off on its own and I can't get it back on unless I relaunch Mach3. Not sure why it does this. It's not a big problem, just pauses around arcs.
Any help would be great :)
P.S. It's not in the program, since I can run the same program for days, then all of a sudden it does it (turns CV Mode off).
Re: CV Mode turns off by its self
« Reply #1 on: June 02, 2012, 05:32:49 PM »
Are there any Canned drill cycles in your program ? Some will turn OFF the CV as part of the canned cycle but FAIL to turn it back on when done.
Just a thought, (;-) TP
« Reply #2 on: June 03, 2012, 03:46:25 AM »
I've had this happen - often.
Instead of a restart, I edit the program headder when it happens to add G64.
Bit of a pain, but I live with it ;-)
ATB
You can "chop it off" but can't "chop it on"
« Reply #3 on: June 13, 2012, 06:06:13 PM »
Worked GREAT.. Thanks!! :)
« Reply #4 on: June 19, 2012, 06:05:39 PM »
The funny thing I see when this happens is that the check box on the general config page gets unchecked as well.
I have just added a G64 to the beginning of all my programs that use G64.
