Hello
Guest
it is
November 13, 2026, 05:00:35 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
PoKeys
(Moderator:
NeoTO
pokeys 56 + poextbusre
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: pokeys 56 + poextbusre (Read 16275 times)
tantan
130
on:
June 02, 2012, 03:09:16 AM »
hi, does somebody has an example how to switch on/of relays on the poextbusre board with mach3
i use the latest mach, pokeys and plugin software
Logged
NeoTO
504
Re: pokeys 56 + poextbusre
Reply #1 on:
June 03, 2012, 10:02:12 AM »
How do you want to control these outputs?
You can open the device configuration in the PoKeys plugin dialog and assign a
* 'OEM LED' to PoExtBus mapping (controlling the outputs with various signals in Mach3)
* Mach3 standard input/output to PoExtBus mapping (controlling the outputs with various signals in Mach3 or G-code commands)
* Mach3 IO device to PoExtBus mapping (controlling the outputs with VB script)
Logged
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
tantan
130
Reply #2 on:
June 03, 2012, 10:12:18 AM »
hi, thanks for you reply,
is it possible to become an example for each option. i cannot get this from the user manual of the pokeys or relayboard.
tnx
tantan
Logged
NeoTO
504
Reply #3 on:
June 03, 2012, 10:20:56 AM »
Please take a look at the Pulse engine and Mach3 plugin manual, available at
http://www.poscope.com/productattachments/index/download?id=77
Logged
www.poscope.com
tantan
130
Reply #4 on:
June 03, 2012, 12:04:47 PM »
oke tnx,
i think i know what to do. i give it a try.
tnx again
tantan
Logged
tantan
130
Reply #5 on:
June 06, 2012, 01:52:51 PM »
it works great!
it's amazing how many features this little device has!
tnx
tantan
Logged
Print
Pages:
1
Go Up
« previous
next »
