Hello Guest it is November 13, 2026, 04:48:20 PM
Author Topic: Strange slave axis problem  (Read 24019 times)
« on: May 31, 2012, 10:25:35 AM »
We've been runnning this table for 2 years in a production shop with no issue until now.  In the middle of a job the other day the G540 faulted, we quickly diagnosed it to the A drive (slaved to Y) in the G540 (it was noticably burned and we thought it shorted from metal dust since the controller was REAL dirty inside).  I removed the A drive from the G540 and it came back to life and we limped along driving the gantry from one side.  I bought I new G540 (cheaper to buy one and get extra parts than to buy a new 250 driver) and we installed it today.  It quickly went to fault again.  We swapped all the cables and ran all the steppers on other drives to eliminate a cable or stepper problem with no change we desided to swap drives around in the G540 to see if the issue followed the A driver but it didnt.
I said all that to say this.....the problem has to be within Mach 3.  If I disable the slave drive we don't get a fault and if I enable it and leave the stepper unplugged still no fault but once I plug in the A its fine until I try to jog the table then it instantly faults and it will do this on every combination of cable, stepper and driver.
Re: Strange slave axis problem
« Reply #1 on: May 31, 2012, 11:08:48 AM »
On slaved units I have seen mach3 currupt the XML and cause the Slave drive to run backwards even through the config SAID it was correct.
Try reloading the original backup XML. NOT the backups that MAch3 does.
NOT a good idea to run a drive WITHOUT the motor wired up could cause a drive failure internally.
« Reply #2 on: May 31, 2012, 11:41:57 AM »
Good idea but no dice.
« Reply #3 on: May 31, 2012, 12:18:46 PM »
HUM, I do not know of any way that MACH3 could cause a FAULT on a stepper drive. All it can do is send OUT the pulses for the steps(;-).
It can stall the drives but that is about it.
Just a thought, (;-) TP
« Reply #4 on: May 31, 2012, 01:32:00 PM »
It is possible that I have a bad Parallel Port or cable
« Reply #5 on: May 31, 2012, 01:58:10 PM »
well.....its not the parallel port cable.  We also went back to the old G540 with a new G250 driver installed and its still the same.  I am able to leave the A stepper hooked up without a fault light if I disable the slave axis.  As soon as I enable the slave to the Y and jog the table it faults.
« Reply #6 on: May 31, 2012, 02:10:04 PM »
I remapped the pins and the problem follows the pins (8 & 9)
« Reply #7 on: May 31, 2012, 04:08:49 PM »
Have you tried removing the steppermotor from the unit and leave it hooked to the drive then see if anything changes.
« Reply #8 on: May 31, 2012, 04:41:14 PM »
MIGHT be time to give Gecko a call (;-)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #9 on: June 01, 2012, 03:11:42 AM »
Wouldn't that suggest it's the PP? Those pesky little output trannies probably got burned when the old A drive let the magic smoke out.
Ian
