Hello Guest it is November 22, 2026, 02:28:23 PM
Author Topic: Hot Wire CNC Foam Cutter and GCode  (Read 8995 times)
« on: May 29, 2012, 02:09:37 AM »
Hello,
I am working at a factory where we have one Hot Wire CNC Foam Cutter. Some times the hot wire breaks and the operator, after replacing the hot wire, must manually enter the used tool and the last operating conditions in order the CNC foam cutter to operate normally from present position. Is there any way to start the CNC Foam Cutter with from present position the last operating conditions (Tool, Speed, Position etc) using GCode?
Thanks in advance,
George
