Hello Guest it is November 13, 2026, 09:47:27 AM
Author Topic: Will this modbus device work with Mach3  (Read 10432 times)
Offline drew
  •  79 79
« on: January 10, 2007, 10:05:04 PM »
This looks like a very versatile  I/O unit for less than an arm and three fingers. Is there any hope that it will work with just some VB scripting? My dual pci lpt port card arrives tomorrow should I just chuck it out for this.
http://cubloc.com/product/01_05cbstartkit290.php
[CB290]
- Ideal for apps requiring large number of I/O ports.
- Ideal for apps requiring RTC (Real Time Clock) and data memory back-up during power-down.Ideal for apps requiring large data memory. (e.g. Modbus RTU Master mode)
- Ideal for small to mass production (1 to 1000+), Embeddable in customized PCB
- MODBUS ASCII (Master & Slave Mode) Support
- MODBUS RTU (Master & Slave Mode) Support
- External Peripherals CuNET (I2C) included.
- External Peripherals SPI included.
- Develop using CublocStudio in BASIC and/or Ladder Logic Language.
Processor
 CUBLOC CB290
Microprocessor
 Atmega128 @ 18.432Mhz
Program Memory   (Flash)
 80KB
Data Memory   (RAM)
 24KB(BASIC) + 4KB(Ladder Logic)
EEPROM
 4KB EEPROM
Program Speed
 36,000/sec
General Purpose I/O
 91 I/O lines (5V TTL) (33 input only + 32 output only + 26 input/output configurable)
Serial Ports for Communication
 - 2 High-speed hardware-independent serial ports
- Configurable Baud rates: 2400bps to 230,400 bps
Analog Inputs
 8 channel 10-bit ADCs
Analog Outputs
 - 6 Channel 16-bit PWMs (DACs)
- Configurable Frequency: 35hz to 1.5Mhz
External Interrupts
 4 Channels
High Speed Counters
 2 Channel 16-bit Counters (up to 2Mhz)
Power
 5V, 70mA (ports unloaded)
RTC
(Real Time Clock)
 Yes
Timers
 - 1 User Configurable Timer
- Configurable Interval Units = 10ms
Data Memory Back-up
 Yes, a rechargable Super-Capacitor or Battery may be connected. (The *CB290 Proto-Board and **CuBASE64M comes with Super-Capacitor included on-board)
Operating Temperature
 -40 °C to 120 °C
Package
 108-pin Module
Size
 2.4"L x 1.9"W x 0.5"H (59.4 x 47.8 x 13 mm)
If I had something important to say it would be here.
Re: Will this modbus device work with Mach3
« Reply #1 on: January 11, 2007, 09:59:49 AM »
should...
www.newfangledsolutions.com
www.machsupport.com
