Hello Guest it is October 25, 2026, 04:02:15 PM
Author Topic: mach3 mill Problem with G2/G3 and G18  (Read 15951 times)
Offline kvom
  •  37 37
« on: May 23, 2012, 03:58:52 PM »
Using the mill as a lathe with stock held in mill collet and tool in lathe.
G2 and G3 seem to be reversed.  If I replace G2 with G3 and vise-versa, my part is made correctly.  The toolpath display shows it incorrectly either way.
Re: mach3 mill Problem with G2/G3 and G18
« Reply #1 on: May 23, 2012, 04:15:12 PM »
Are you loading a Turn Profile?
Offline kvom
  •  37 37
« Reply #2 on: May 23, 2012, 04:41:44 PM »
Using standard mill profile.  I did try to use the turn profile that came with the install but I get no fields.  Using the TurnAddon screens I get the same toolpath display.
Same result with both the lockdown and later versions.
« Reply #3 on: May 24, 2012, 02:27:48 AM »
Not really sure what you are meaning by "I get no fields"
Also not sure what you are meaning by "using the TurnAddon screen"
What I would suggest is you clone the profile for your mill and then open it and load a turn screen (1024.lset) and then restart that profile and see what things look like.
« Reply #4 on: May 24, 2012, 05:46:47 AM »
Maybe consider using MSM as that provides for using your mill along with a rotary table as a lathe.
Offline kvom
  •  37 37
« Reply #5 on: May 24, 2012, 07:48:25 AM »
That seemed to resolve the display issue.  I was not aware of the difference between lset and set.
Here's the small part I was making:
I'll try it this afternoon to see if the actual paths are OK.
« Last Edit: May 24, 2012, 07:58:48 AM by kvom »
Offline kvom
  •  37 37
« Reply #6 on: May 24, 2012, 11:01:15 AM »
Checked it on the mill today and got correct paths.  But it seems there must be an issue with G2/G3 and G18 in mill mode.  Not worried about it now though.
« Reply #7 on: May 24, 2012, 12:55:32 PM »
Not thought too much about it but would the G2/G3 thing not be the difference between tool doing the moving and workpiece doing the moving?
Anyway whatever it is if using the mill as a lathe with the work in the spindle the easy option is to use a turn profile where arcs are reversed in front toolpost.
