Hello Guest it is October 25, 2026, 07:54:57 AM
Author Topic: Unusual problem  (Read 10515 times)
Unusual problem
« on: May 22, 2012, 09:13:48 AM »
I'm having a strange issue, for some reason I can no longer jog from anything other than my shuttle pro based mpg.  We have changed no settings anywhere and when I click the "jog" mode select on the on screen mpg, none of the options (step, cont. etc) illuminate.  I can't use the virtual buttons or my keyboard arrow keys anymore.  Any thoughts?  This machine is used in a production environment and gets a full shift of use daily and no one ever changes any settings so this is a little odd.
Re: Unusual problem
« Reply #1 on: May 22, 2012, 10:17:52 AM »
Attach your xml and I will have a look.
Re: Unusual problem
« Reply #2 on: May 22, 2012, 10:20:31 AM »
fixed it, silly thing, the jog was toggled off in tool settings.  Never even noticed the buttons.
-Ed
Re: Unusual problem
« Reply #3 on: May 22, 2012, 10:25:02 AM »
You must have previously had it set on MPG as if it had been on Keyboard Jog the virtual buttons would still have worked even with the Jog Control off.
Good you got it though :)
