Hello Guest it is November 12, 2026, 06:01:01 AM
Author Topic: CorelDraw DXF export file does not load in Lazycam  (Read 36812 times)
Re: CorelDraw DXF export file does not load in Lazycam
« Reply #10 on: January 10, 2007, 01:03:45 PM »
Here is the file I created using CorelDraw 7. When I try to load this one, I get an error that Lazycam cannot find any entities.
« Reply #11 on: January 10, 2007, 02:17:22 PM »
I save these as Autocad DXF 2000. Must be a little different than Corel. Can you save these in another program and try saving them as a DXF?
« Reply #12 on: January 10, 2007, 03:13:28 PM »
Try this converterhttp://www.a9tech.com/products/a9converter/
Make the output file DXF
Make the output verson autocad 12
Then drag and drop your CorelDraw File into the converter then hit convert
« Last Edit: January 10, 2007, 03:23:17 PM by c1nel2 »
« Reply #13 on: January 10, 2007, 03:45:32 PM »
I tried William in Turbo Cad 6 and saved as a DXF. This did not load in Lazycam either, got msg that no entities found in the file.
« Reply #14 on: January 10, 2007, 04:00:12 PM »
I tried the A9 converter however it will not accept as imput a .cdr file which is the natural output for CorelDraw files. Thanks for the suggestion
« Reply #15 on: January 10, 2007, 04:05:03 PM »
In CorelDraw export as a DXF.  Autocad 11 format it will work
« Reply #16 on: January 10, 2007, 04:39:51 PM »
I exported from CorelDraw as a plt file and it loads directly into Lazycam. I exported a DWG file and used the A9converter to make a DXF file and it worked fine. I wonder what is wrong with LazyCam and my versions of CorelDraw ? I also tried the file export in Turbocad ver 6 and it did not work either as a DXF file. BTW, when exporting, I do not get the option to create version 11 file, only to 13 and up.
« Reply #17 on: January 29, 2007, 09:55:18 AM »
Try the DXFTool from CandCNC (http://www.candcnc.com/DXFToolDetails.htm) it works with CorelDraw V12 and X3.
-James Leonard'
« Last Edit: January 29, 2007, 11:39:54 AM by Graham Waterworth »
« Reply #18 on: January 29, 2007, 03:13:17 PM »
Thank you for the suggestion. I will look into it when I get my hardware working better. My plasma torch is acting weird. At the moment, I am having success with exporting hpgl plt files. They load into LazyCam with no problems.
