Hello Guest it is November 22, 2026, 02:28:44 PM
Author Topic: Cambam question  (Read 11937 times)
Cambam question
« on: May 15, 2012, 02:54:02 AM »
Hi
Question, when I draw a shape in Cambam using polyline, How do I determine its size? The tutorial video covers everything  to do with creating and machining it but not how big it is.
Are the grid lines 1mm? if so, what if I wanted to draw something that was 50.5 between 2 points for example?
Hope you can assist
Al
Re: Cambam question
« Reply #1 on: May 15, 2012, 04:42:39 AM »
Hi, patly answered my own question, yes, its 1mm grid lines. Can I change the resolution or is there another method to set a dimension between squares?
Cheers Y'all
Al
Re: Cambam question
« Reply #2 on: May 15, 2012, 05:15:42 AM »
Don't use CamBam's CAD so can't be of much help other than to say if you don't get a response here that you go to the CamBam site
have a look at the videos, manuals, etc and maybe register for the forum and ask there.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Cambam question
« Reply #3 on: May 18, 2012, 07:04:08 AM »
Select the item in the menu tree and click on its properties, there will be a list with height, width etc, just enter new values and press enter.
« Last Edit: May 18, 2012, 07:07:57 AM by Graham Waterworth »
Re: Cambam question
« Reply #4 on: May 21, 2012, 03:51:44 AM »
Hi you can also use points > collection ....  click on ....  brings up the table  which can be edited
Regards
Nick
