Hello Guest it is November 07, 2026, 01:23:14 PM
Author Topic: feed rate button on program run screen  (Read 11681 times)
« on: May 13, 2012, 07:11:16 PM »
Sometimes I would like to be able to speed up or slow down my feed speed when using my router.  I assume that the Feed Rate button should allow me to do that, but it doesnt.  What do I need to do to activate this feature?  Thanks
Re: feed rate button on program run screen
« Reply #1 on: May 13, 2012, 07:42:00 PM »
IF you have the standard screenset then in the Feedrate control block there are 2 arrows one pointed down with a - in it and the other is pointed up and has a + in it.
Click on either and the FRO will increase/decrease  by 10%   for each press of the arrow.
« Reply #2 on: May 14, 2012, 05:45:24 AM »
Think the standard screens now use a slider for FRO, you would just click and hold the left mouse on the green part of the slider and move the mouse up or down.
« Reply #3 on: May 14, 2012, 12:43:51 PM »
when I click on the arrows, the screen indicates that the speed is changing but in reality it does not change.
« Reply #4 on: May 14, 2012, 12:49:08 PM »
On general config page do you have No FRO on Queue ticked, if so untick. Other thing is you may be calling out a M49 in your code and that will disable FRO.
« Reply #5 on: May 15, 2012, 07:36:04 PM »
Thanks Hood.  The No FRO was ticked.
