Hello Guest it is September 06, 2026, 02:49:36 AM
Author Topic: help  (Read 33762 times)
Re: help
« Reply #10 on: May 15, 2012, 04:41:18 AM »
If you are inputting a G01 move you must set a feed rate. At startup there is no prior feedrate for the machine to use. If you hit veryify I think that it will leave a feed rate = to the homing speed in the system. Try a G01 f20 x 5 or something similar and see if that works.
Mike
Offline dude1
  •  1,253 1,253
Re: help
« Reply #11 on: May 15, 2012, 08:40:47 PM »
tried all of that same problem, start up, hit reset same problem axis moving very slow. i can push stop or verify to clear problem once hit stop or verify z goes up 20 then down 20 then all good.
have put xml on to another computer same problem must be a ghost in the xml
Re: help
« Reply #12 on: May 16, 2012, 02:22:29 AM »
It does not happen here with your xml so it is hard to see how it is an issue with the xml, assuming that is you attached the correct xml?
As I said earlier I loaded the standard screenset as I dont have that one you are using. So the only things I can think that would cause your issue are the screenset, a plugin or a brain.
There is no way the Z axis should move at all just by pressing the Stop button, that suggests there is VB in that button on the screenset you are using or you have a brain or macropump doing something when that is seen.
Offline dude1
  •  1,253 1,253
Re: help
« Reply #13 on: May 18, 2012, 06:18:01 PM »
i have tried this xml on 3 different computers with same result when you start Mach hit reset then go to MDI screen and type in a move its still slow as, but you can jog with key board or fly out screen that run at correct speed and if you load a g code that will work ok its just when you type in a move in the MDI screen after you start up this problem exists, if you hit stop or verify before inputting move its gone.
Re: help
« Reply #14 on: May 18, 2012, 07:26:42 PM »
In General Config, put F150 in your initialization string and see if it's faster.
Re: help
« Reply #15 on: May 19, 2012, 03:24:29 AM »
What are you entering in MDI?
Offline dude1
  •  1,253 1,253
Re: help
« Reply #16 on: May 19, 2012, 04:43:44 PM »
something like G0 X200
Re: help
« Reply #17 on: May 20, 2012, 02:16:58 AM »
Well I have tried many times with your xml, even installed a couple of different versions of Mach and also downloaded that screenset and still it behaved.
Offline dude1
  •  1,253 1,253
Re: help
« Reply #18 on: May 20, 2012, 04:12:36 PM »
the problem is to do with the initialization string if I type say G0 f300 x300 into the mdi screen its ok but if I type G0 X300 its not ok its some thing I can live with, thanks for all of your help.
Re: help
« Reply #19 on: May 20, 2012, 04:23:34 PM »
A G0 is a rapid move and it should not matter what F word is in the initialisation string so I am perplexed why this would work. I could understand if you were commanding a G1 move but not a G0 as you are.
It would be good if someone else would try your xml and see if they have the problem, so hopefully someone will.
