Hello
Guest
it is
November 22, 2026, 07:01:54 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Motor tuning- missing save button??
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Motor tuning- missing save button?? (Read 9414 times)
Fred_evans
396
on:
May 10, 2012, 04:19:56 AM »
Hi guys--
I am going to tune the motor on the Z axis and am following the instructions in the manual:-
Section 5.6.1.4 says
"5.6.1.4 Mach3 steps per unit
So now we can finally calculate:
Mach3 steps per unit = Mach3 steps per rev x Motor revs per unit
Figure 5.9 shows the dialog for Config>Motor Tuning. Click a button to select the axis
which you are configuring and enter the calculated value of Mach3 Steps per unit in the box
above the Save button.. This value does not have to be an integer so you can achieve as
much accuracy as you wish. To avoid forgetting later click Save Axis Tuning now"
But on my Figure 5.9 there is no save button??
Where must i enter the value calculated?
regards
fred evans
Logged
Re: Motor tuning- missing save button??
Reply #1 on:
May 10, 2012, 04:29:59 AM »
Not sure what manual you are using. Irrelevant, since in the Motor Tuning Screen there is a button "Save Axis Settings "
unless your using a different screen other than the standard screen. The calculated value is input in the "Steps per".
Logged
Fred_evans
396
Reply #2 on:
May 10, 2012, 07:20:56 AM »
thanks Rich-- problem solved
Logged
Print
Pages:
1
Go Up
« previous
next »
