Hello Guest it is September 29, 2026, 09:29:07 PM
Author Topic: OEM Trigger  (Read 10619 times)
OEM Trigger
« on: January 08, 2007, 12:06:42 PM »
What is the call for OEM Triggers?
I tried Get OEMTrigger (4) with no luck.
Darek
Re: OEM Trigger
« Reply #1 on: January 08, 2007, 01:55:31 PM »
This is what I am trying to do,
Darek
If GetOEMTrigger (6) = 0 Then
   If GetOEMTrigger (7) = 0 Then
      DoOEMButton (191)   'Select Jog Incr 1
EndIf
If GetOEMTrigger (6) Then
      DoOEMButton (192)   'Select Jog Incr 2
EndIf
   If GetOEMTrigger (7) Then
      DoOEMButton (193)   'Select Jog Incr 3
EndIf
      DoOEMButton (194)   'Select Jog Incr 4
EndIf
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: OEM Trigger
« Reply #2 on: January 08, 2007, 03:50:14 PM »
I think the triggers start at number 29
So you maybe have to look at 35 and 36 to get the ones you want.
Graham.
Re: OEM Trigger
« Reply #3 on: January 09, 2007, 05:52:16 AM »
Your right! This is what I ended up with.
Darek
If Not IsActive (34) Then If Not IsActive (35) Then               'Check OEM Triggers 6 & 7
End If
If IsActive (34) Then If Not IsActive (35) Then                     'Check OEM Triggers 6 & 7
End If
If Not IsActive (34) Then If IsActive (35) Then                     'Check OEM Triggers 6 & 7
End If
If IsActive (34) Then If IsActive (35) Then                           'Check OEM Triggers 6 & 7
End If
