Hello Guest it is November 22, 2026, 10:05:34 AM
Author Topic: Mach3 hitachi x200 modbus  (Read 11453 times)
Offline tpmx
  •  11 11
« on: May 08, 2012, 08:17:52 AM »
Can someone please shed some light on my problem
Getting modbus working with a hitachi x200 ?
I have read for days on this and i believe i have it set up correctly
But i get timeout errors once i open the port and try to read data
I have a rs232 to rj485 on a pci serial port card
I get no errors in mach opening and closing the port so this much
I think is right
I have the baud rate and settimgs setup on the pc to match mach
I have the swith on the vfd to rj485
Seems to be from the converter to the vfd where my probl lies
Just not sure where to lool now
Offline tpmx
  •  11 11
Re: Mach3 hitachi x200 modbus
« Reply #1 on: May 08, 2012, 04:37:18 PM »
Here is the rs232 adapter I am using.Not sure how you tell which is the right RS232-RJ485 adapter
to us
If someone could possibly check this out to see if i am on the right track here
http://www.ebay.com/itm/251044973696?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_2570wt_1138
