Hello Guest it is October 21, 2026, 12:24:05 PM
Author Topic: Sanyo Denki Stepper ?'s  (Read 13680 times)
« on: May 06, 2012, 09:48:25 AM »
Hey folks,
  I recently picked up a batch of Sanyo Denki stepper motors.
Some are ... Type : 103-845-6741     12-300 V     6.7 A   Stall Torque 3.4 Nm (Should be perfect with a Gecko ?)
I found gads of info on these, but cannot find any info on the others, which are:
Type : 103H82236540    12-300 V       9A      7.05 Nm
I'm trying to find a suitable driver for the 9A model. It's over the Gecko 7A limit so I suppose it would destroy the Gecko ... or is there a way to limit the load on the driver and use the combination anyway ?
Thanks first,
Russ
Re: Sanyo Denki Stepper ?'s
« Reply #1 on: May 06, 2012, 11:24:15 AM »
The Gecko's dictate the current, not the motor. Set the Geckos for 7 amps and your good, but you'll lose about 25% of the rated torque (7รท9).
Larken makes a 10 amp drive. http://www.larkencnc.com/motion/steppers.htm
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #2 on: May 06, 2012, 12:08:14 PM »
here you go for the 103H82236540 Russ (page 22)
Ian
« Reply #3 on: May 06, 2012, 05:13:23 PM »
Gerry,
   The Gecko set at 7a is no resistor installed.. Just wasnt sure if it was protected internally at that point or if it would fry, Thanks !
Thank you Ian, just what I was hunting for.. Perfect!
Russ
