Hello Guest it is November 23, 2026, 06:09:03 PM
Author Topic: 2 DRIVE MOTORS 1 AXIS  (Read 8012 times)
« on: May 05, 2012, 05:18:39 PM »
I'm new to the CNC world and in the last stages of building my machine. I have Mach3 installed and have motor movement on all 4 while testing using the arrow keys on my keyboard. However I have 2 motors on my "Y" axis but only one spins when running the Road Runner G-Code in the Mach3 demo. How can I get both motors synced up to run together?
Re: 2 DRIVE MOTORS 1 AXIS
« Reply #1 on: May 05, 2012, 05:21:06 PM »
Set one as A and then make sure its set as a linear axis in General Config then you can select to slave it with Y axis, its from Config menu. Restart Mach and it should now move when the Y moves.
« Reply #2 on: May 05, 2012, 10:35:56 PM »
Worked as described....much appreciated!
