Hello Guest it is November 01, 2026, 01:06:39 PM
Author Topic: Experienced Lazycammer Wanted!  (Read 54078 times)
« on: May 03, 2012, 11:14:25 AM »
Hello all, I finally have my DIY plasma table working well now I just need to figure out the software side of it. I am having trouble converting my drawings into Gcode. I am able to do simple shapes but I can't seem to get all the steps correct for slightly more complex drawings. I am attaching a drawing that I am struggling with it is 5 letters that I created. I am also attaching the gcode file that I created. I am using LazyCam and Mach3. If someone can give me the step by step instructions they used to get the entire image to show up in Mach3 I could probably learn from that. HELP!!!
Re: Experienced Lazycammer Wanted!
« Reply #1 on: May 03, 2012, 04:28:59 PM »
You don't say what you want to do with the letters.
You will find a users manual for Lazycam in Members Docs and strongly suggest you have a read and not hack at the program.
« Reply #2 on: May 04, 2012, 11:19:39 AM »
I want to use it on my plasma machine. I have looked through the manual and since it's geared towards mill operations it is difficult to coorelate it with the plasma. I figured someone with LC experience could do this quickly. When I load in Mach it does not show the complete drawing.
« Reply #3 on: May 04, 2012, 09:14:34 PM »
The manual dosen't cover plasma. The reason is simple. I don't have or use a plasma machine and in that light would not know what quirks to look for in the program. Anybody out there is free to write a section on LazyCam Plasma and post it. There is no documentation for LazyCam other than the numerous hours I spent hacking it to death for the lathe and mill.  So the only support I tend to offer is for the mill part of LazyCam ( consider the Lathe module dead as it is now replaced by LazyTurn).
« Reply #4 on: May 06, 2012, 05:41:53 AM »
RAYSURFER,
Tried your dx in both LC mill and Plasma. No problem in mill. Trying LC Plasma I only got two letters also the first time I tried posting the code. BUT...... Went out of LC, reloaded LC , and posted again and the complete code was posted.
Do you have a licensed copy of MACH and do you have the Pro license of LC ?
There is a line limit in LC if you don't have a licensed for MACH and LC also restricts the different LC Modes if it is not the
Pro Version.
« Reply #5 on: May 06, 2012, 09:36:38 PM »
In fact I have not purchased a license yet. I am trying to figure out which CAM software to purchase. A lot of them will package Mach3 with their software. If I purchase the Mach license from Artsoft does it come with an unrestricted version of LazyCam? Do you know?
Thanks for loading it, I wanted to make sure it was something I was doing wrong.
« Reply #6 on: May 07, 2012, 05:36:49 AM »
Lazycam will still be restrictive even if you purchase Mach. See page 4 of 123 in the manual which can be found in
Member's Docs which provides more information. There is no documention on Plasma in the manual and your on your owne.
« Reply #7 on: May 24, 2012, 12:02:07 PM »
i have never needed anything but lazycam for plasma.i find that arcs can be a pain so after drawing shape , i explode all and then join polylines. i use turbocad vers 10.  i then offset to the inside or outside the width of the plasma kerf and delete the original lines. save as r14 or earlier dxf.  open in lazycam , relayer opimize, reset origin, cset the leadins
and direction form the popup dialog box. set the speeds and feeds  in the dialog box , post and save.i know that everyone says that sheetcam is better and i have played around with it but, i can go from importing a dxf into lazycam and be cutting in less than 1 minute. i also have customized the plasma post processor so that it auto inserts the safe z, start z, and plunge speed z . been using it for 4 years now.
« Reply #8 on: May 24, 2012, 06:06:12 PM »
Thanks tripleblack for the feedback. I am trying out the sheetcam. I think my issue with LC might have been that I was using an unlicensed version. I am reluctant though to sink the $75 for the software when it's dead though. So I might go with the sheetcam since it's still active.
« Reply #9 on: May 24, 2012, 09:40:32 PM »
For Plasma work SheetCam all the way, No comparison.
Just a thought, (;-) TP
