Hello Guest it is November 23, 2026, 05:55:07 PM
Author Topic: rapids are executed very slowly  (Read 8794 times)
« on: April 29, 2012, 08:00:38 PM »
I am having a problem with my G0 moves always running very slow. Whether the code is generated by lazy cam or input manually they always run real slow. If I edit the programs and change to G1 with a feed rate they work as they should. Is there a setting in configurations I am missing that is causing this ? Any help appreciated. Thanks
Re: rapids are executed very slowly
« Reply #1 on: April 29, 2012, 08:09:19 PM »
Do you have your rapid Feed Rate Override set to less than 100%?
« Reply #2 on: April 30, 2012, 10:25:39 PM »
I am not sure. Is there a place to do this other than the general feed rate override on the main Mach control screen ? I cannot find anything labeled rapid feed rate override. I did discover in trying to make sure I had main screen override set at 100 % and then running a program that initially the rapids will run at about 10, but if I stop the execution and then start it again it will jump up to 50 or 100 and then if I stop it and start again it goes back to about 10 ?
« Reply #3 on: May 04, 2012, 09:59:06 AM »
Brett, Thanks for your help. I finally found the rapid overide setting and it was limiting the the speed.
« Reply #4 on: May 04, 2012, 07:00:42 PM »
Sorry I missed your first reply to my post Scott but glad you got it sorted.  :)
