Hello Guest it is November 13, 2026, 10:40:09 AM
Author Topic: z axis is not working  (Read 9766 times)
« on: January 07, 2007, 04:19:47 PM »
ever time I set auto zero the router lowers touchs the plate then raises to hits the limit switch. I have to home ref and start over now the router its self will not turn on. It works five if I plug it in by itslelfs. I have unstall mach3 and installed agan. If anyone has a suggestion I'am all ears.
Max
Re: z axis is not working
« Reply #1 on: January 07, 2007, 06:25:49 PM »
Could you please post the code that you are running to auto zero the tool? I think we can find a way to make it work
Brian
www.newfangledsolutions.com
www.machsupport.com
