Hello Guest it is October 22, 2026, 08:40:52 PM
Author Topic: G code stops part way through .  (Read 9155 times)
« on: April 28, 2012, 05:10:52 PM »
I use the free version of Mach3. I generate my G code with Vcarve pro 6.5. I save my G codes as tap files. When I load them into Mach 3 and run them, they cut fine then they stop for no apparent reason. I have tried 3 different profiles in Mach 3 as I had one profile go bad and not work. But even with a new profile my G codes only go part way and then stop. I am at a loss as to why this happens. Even the road runner sample G code stops part way through. Could this be because I am using the free version?  Any suggestions would be appreciated.
Safe machining everyone
Re: G code stops part way through .
« Reply #1 on: April 28, 2012, 05:25:34 PM »
There is a limit to the number of lines in Mach demo. So you are exceeding the limit.
« Reply #2 on: April 28, 2012, 05:29:17 PM »
Thanks I just read some other posts that refered too that. So I have just purchased the full version.
