Hello Guest it is November 13, 2026, 06:28:00 PM
Author Topic: Problem with DEV Version .062  (Read 7518 times)
« on: April 24, 2012, 09:04:36 AM »
Hello to all
Well I downloaded the last version .062 and try it and  i get a really weird thing,When loading the G-Code the generating path window open but stays open and no paths are generated,then Mach freezes,here is where i click on the RESET button and Mach started to generate the path and work for a while then I will get random e-stops during the cut.Using Win XP service pack 3 .
Any ideas how to fix this issue?
Thank you.
Marco.
