Hello Guest it is November 13, 2026, 05:19:41 PM
Author Topic: Pin 53,54 and 55 in Pokeys56U in Step Pulse Mode  (Read 12309 times)
Offline txpto
  •  26 26
« on: April 16, 2012, 03:47:24 PM »
Hello I'm drawing a schematics with OrCad and I am making a component Pokeys56U in Orcad library.
I will use in Step Pulse Mode.
I only have 3 things to clarify:
in Page 70 of PDF User Manual 5/2/2012:
pin 53 - Conection Signal
What is this ?
pin 54 - Configuration Reset or Special Functions
How make a configuration reset or what type of Special Functions are ?
pin 55 - Connection signal
What is this ?
- Pokeys56U Board arrive at my home today. All perfect. Board is really little and compact. Is perfect for make a custom mother board and put it on.
Thanks a lot for all.
Carlos
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pin 53,54 and 55 in Pokeys56U in Step Pulse Mode
« Reply #1 on: April 17, 2012, 03:28:47 AM »
Connection signal: the outputs that are set as connection signal output, indicate whether the connection with the PC is active or not - when the connection (Ethernet link, USB connection) is dropped, this signal state will change to indicate this. It can be enabled on selected pins, but is disabled by default.
Pin 54 is used for recovering the device if it gets misconfigured. This pin should not be connected to GND on device initialization, as the device will enter the recovery mode. When the device enters normal operation, this pin may be used for any digital IO function.
Offline txpto
  •  26 26
« Reply #2 on: April 17, 2012, 10:04:20 AM »
Thanks a lot for information.
if I connect  a leds on this outputs signal , I can read status of pokeys.
Thanks.
