Hello Guest it is November 23, 2026, 07:37:16 AM
Author Topic: Drawing a clock gear for CNC in Bentley Microstation  (Read 8867 times)
« on: April 11, 2012, 08:25:47 PM »
The PDF is a 7 page tutorial on drawing a clock wheel to use in a mill to cut out a wheel blank. The CAD program is Microstation but the idea can probably be used in other programs. I've used this procedure to do all the wheels for Wilding's English Regulator movement, run the drawings through LazyCam and Mach3 Mill and cut them out on a CNC Taig mill.
