Hello Guest it is November 13, 2026, 05:01:47 PM
Author Topic: New plugin and analog inputs  (Read 14049 times)
« on: April 11, 2012, 08:51:56 AM »
I have a PoKeys56U with 2 potentiometers attached at analog pins 44 and 45. With the new plugin the pots do not work any more with mach3. How can I tell Mach (and the plugin) that this is an analog input? Up to now I used brains to do this, but there is also no reaction visible in the brain control in Mach3 when the new plugin is in use. With 10.6.4 it works properly. My PoKeys version is 3.0.28.
Has anyone an idea?
Martin
Offline NeoTO
  •  504 504
    • PoLabs
Re: New plugin and analog inputs
« Reply #1 on: April 11, 2012, 08:56:29 AM »
Analog inputs are not yet supported in new plugin. The support for analog inputs will be added soon.
« Reply #2 on: June 10, 2012, 08:12:24 AM »
I have the same problem. Is there any help available at the moment?
I do need the analog inputs, so perhaps I could switch back to an older
plugin. My Pokeys are updated to V3.030.
Wolfram
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: June 10, 2012, 02:47:14 PM »
Wolfram
The 'beta' version of the plugin, released 10 days ago, support analog inputs.
