Hello Guest it is November 13, 2026, 09:35:33 AM
Author Topic: Hobby cnc board work with 127 oz steppers and not with 200 oz steppers  (Read 12455 times)
Haai
I have the hobby cnc pro driver board and 200 oz 3A steppers when turning the bord on and telling the steppers to move with mach 3 the stepers bind for 1/2 a second and then I can turn the steppers with my hand but dont turn at all
I connected my foamcutter steppers (127 oz 1 A) to the same board and they work fine
Dave Rigotti (hobbycnc.com) thinks it might be some setting in mach 3 that I got wrong
Please help
Thanx
Johann Badenhorst
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Hobby cnc board work with 127 oz steppers and not with 200 oz steppers
« Reply #1 on: January 05, 2007, 09:50:44 AM »
Have you set the acceleration and velocity under motor tuning.
Graham.
« Reply #2 on: January 06, 2007, 03:09:48 AM »
yes it is set to
                        X axis                Y Axis                  Z axis
steps per mm -   2130                  2130                    2130
velocity          -   300                    300                     200
acceleration    -   100                    100                     100
step pulse      -    5                         5                        5
dir pulse         -    5                         5                        5
if not correct please tel me wat it should be
other settings:
Driver bord is set to 1/16 steps
and as I said the smaller 127 oz 1A steppers work great
Graham
Will you please send me your settings for mach3 so that i can just get jhe motors running and I can then later set it for my router
Thanx
Johann Badenhorst
  •  2,785 2,785
« Reply #3 on: January 06, 2007, 04:00:34 AM »
Hi Johann,
every set up is different and you have to set each motor to its optimum by playing around with the setting until you get it running nice.
My settings are :-
steps per mm -     800                     800                     880
velocity          -   1750                   1750                    2250
acceleration    -      55                       65                       50
step pulse      -        1                         1                        1
dir pulse         -        1                         1                        1
Try them but there is no guarantee they will work for your set up.
Graham.
