Hello Guest it is October 20, 2026, 02:55:14 PM
Author Topic: English or Metric setting  (Read 8942 times)
Offline gda
  •  7 7
« on: April 06, 2012, 09:23:02 AM »
Can someone here telll me exactly where to set Mach 3 for either English or Metric dimensions, so that
Mach 3 and my CAD program (Rhino) are on the same page?
gda
Re: English or Metric setting
« Reply #1 on: April 06, 2012, 12:32:31 PM »
This depends on what you mean. If you predominantly use Metric or Imperial then you want to set that from Config menu then Native Units. That will mean that all units will default to what you have chosen and you will have to make sure your steps per unit are also in that unit ( Inch or mm).
If however you are just asking how to run metric code on a machine with Imperial Native units, or vice versa, then G20 or G21 at the start of your code will do that.
