Hello Guest it is October 21, 2026, 04:05:27 AM
Author Topic: Control spindle speed with potentiometer and pokeys board  (Read 14529 times)
« on: April 05, 2012, 12:07:47 PM »
Hi all
I need some help!
I have a pokeys 56U board and I have a potentiometer connected to it. I want to able to control my spindle speed with it. How would I go about doing this. Would I need to use brains? If so what formula would I need?
I also want to be able to change the feed rate with a different potentiometer.
Raul
Re: Control spindle speed with potentiometer and pokeys board
« Reply #1 on: April 05, 2012, 12:45:25 PM »
You can use a Brain or the macropump. I have posted Brans before in the pokeys section that I used for FRO and SRO.
« Reply #2 on: April 05, 2012, 12:59:06 PM »
Hood,
Thank you for your response. I am trying to find your post. Any chance you can give me the link to your post on the FRO and SRO.
Thanks again,
Raul
« Reply #4 on: April 05, 2012, 01:13:57 PM »
Thank you once again.
Raul
« Reply #5 on: April 05, 2012, 01:22:50 PM »
No problem. I have not looked at the Brains I linked to since I posted but I am almost certain they are the same as I use now with the exception of the formula will be slightly different as I now use a PLC for the pots rather than the PoKeys.
