Hello Guest it is November 07, 2026, 04:39:53 PM
Author Topic: THC 301 install file  (Read 10631 times)
« on: April 02, 2012, 06:29:00 AM »
Hello
having some problems here, I have mach 3 installed on a 32-bit Vista system having no problems running the demo but when I load the THC 301 install file, and then start a user profile the mach 3 screen is only partially visible and the locks up immediately
can anybody help me with this  problem ? i've tried loading and reloading it many times and it's always the same
I am using the link off of randy ray's Texas microcircuits
Re: THC 301 install file
« Reply #1 on: March 09, 2013, 04:39:54 AM »
Hello,
Download and unzip the THC 301 files. Copy the unziped files on the Mach 3 files.
Start again Mach 3 in loader mode and select THC 301.
I make like in the manual and works.
BUT I have another problem: the READY led doesn't work even I check the parallel port 2 and the THC 301d with the tester cards from the kit.
The THC 301d when is tested with cables connected it works according with operator manual at test page.
When is connected at the PC on parallel port 2 doesn't works and the READY led is off.
