Hello Guest it is October 20, 2026, 06:52:09 PM
Author Topic: shuttle pro acting up  (Read 9151 times)
Offline josh
  •  101 101
« on: April 01, 2012, 08:16:31 PM »
I had to edit my macro for my lazer.
but know I am having a problem it will work when I press it on the mach sreen , but when I use my shuttle pro button it will also work but not to the cordinates the I edit it to .
is there something else I have to do to make it go to the knew cordinates.
Offline josh
  •  101 101
Re: shuttle pro acting up
« Reply #1 on: April 02, 2012, 08:19:08 PM »
WOW no one  has ever had this problem.
« Reply #2 on: April 03, 2012, 07:11:50 PM »
Sounds like when you saved the edited macro, that you did not save it to the same macro number that your shuttle pro is set up for.
