Hello Guest it is October 17, 2026, 01:44:37 PM
Author Topic: Change a DRO when activating an input with Brains  (Read 9836 times)
« on: April 01, 2012, 06:37:42 PM »
Hello all,
I am trying to create a brain control that when I activate Input #1 it changes the DRO #3(Slow jog rate DRO screen 50) to a specified rate?
Raul
Re: Change a DRO when activating an input with Brains
« Reply #1 on: April 01, 2012, 08:07:49 PM »
Not sure about the brain, but you can add a vb script  button on the screen with a shortcut key activated by Input 1.
« Reply #2 on: April 01, 2012, 10:59:43 PM »
That is the way I have it right now. I was looking to see if there was a way with brains. So no matter what screen i'm in, brains can read the input.
Thank you for your response ger21
Raul
« Reply #3 on: April 02, 2012, 10:59:01 AM »
« Reply #4 on: April 03, 2012, 10:19:40 PM »
ger21 thanks for the response.
Well after viewing that post, fooling around with brains and looking at different brains for MPG's, I figured out how to change the DRO for slow jog rate via an input. I used a lobe formula that I have no idea how it works but it works! I installed a 6 position selector switch on the control panel that I am putting together. Wired up the selector switch to pokeys, I used OEM Triggers as the inputs and created a brain that will give me 6 specific percentile rates for the slow jog rate. The rates that I created was 5,10,20,50,80 and 100%. I have attached the brain file.
Maybe someone might be able to explain how the lobe formula works.
Thanks again,
Raul
