Hello
Guest
it is
November 13, 2026, 05:19:55 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
PoKeys
(Moderator:
NeoTO
Is there a way...
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Is there a way... (Read 11923 times)
SScnc
77
Is there a way...
on:
March 31, 2012, 04:51:56 PM »
Is it possible to bring in sensor inputs from something like a proximity switch on the pokeys?
Logged
NeoTO
504
Re: Is there a way...
Reply #1 on:
April 02, 2012, 01:24:17 AM »
What kind of output does this switch have?
If it has an analog output use the appropriate voltage attenuator first and connect it to the analog input pin (PoKeys has the limit of max. 3.3V on those pins).
If the switch has 4-20mA current output, use an appropriate resistor and connect it to the analog input pin similarly as above.
Give more details on the proximity switch to help you further.
Matevž, PoLabs
Logged
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
poppabear
2,235
Briceville, TN, USA
Reply #2 on:
April 03, 2012, 08:52:25 PM »
Prox's usually run at 24vdc (sinking or sourcing), to interface to the PK, you could
do it through a Solid state relay, or if speed not real important, a standard relay.
Scott
Logged
Print
Pages:
1
Go Up
« previous
next »
