Hello Guest it is October 24, 2026, 12:00:00 PM
Author Topic: How can I adjust the speed of Jogging ?  (Read 28725 times)
Mike S.
« on: February 03, 2006, 01:06:56 PM »
I am a new user of mach3 and am haveing a terrible time Jogging. How can I slow down the jog speed, It is jumping all over the place. Any help would be appreciated.
Offline nicad
  •  40 40
Re: How can I adjust the speed of Jogging ?
« Reply #1 on: February 03, 2006, 01:18:55 PM »
I do not know what version of Mach you are using, but I believe at least on all of them, if you goto the Diagnostics screen, it will have the jog speed listed as a percentage (of your max speed). you can change this by either clicking the buttons with the mouse or hitting the "[" key.
The "]" will increase the jog speed.
on a side note, holding the SHIFT key while jogging will override to full jog speed. Make sure you shift key is not stuck (has happend to me in the past-- got another keyboard!!).
« Reply #2 on: February 04, 2006, 03:49:44 AM »
in Mach3 Press the "Tab" key and you will get a slide out with the SLOW JOG DRO with arrows to make it higher or lower.
www.newfangledsolutions.com
www.machsupport.com
