Hello Guest it is November 22, 2026, 02:24:51 PM
Author Topic: H0 AND D0  (Read 9022 times)
Offline josh
  •  101 101
H0 AND D0
« on: March 25, 2012, 09:56:17 PM »
how do you use this to in your program and can some please explain what they mean.
how and what does it mean H0 and D0 in you program.
I think H means you tool offset so should I write the tool  number  I am using or shoul I leave at 0?
For D should I put the tool diameter?
can someone please explain how to use this two
I would greatlly appreciated
thank you
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: H0 AND D0
« Reply #1 on: March 26, 2012, 07:50:32 AM »
H0 & D0 should be more like H1 D1 and are used along with G41, 42 & 43
G43 H1 sets the tool height offset to offset 1 in the tool table. Hnn can be in the range of 1 to 254
G41/42 D1 tells tool compensation to use diameter offset 1 from the tool table to adjust the tool path by the rad of that tool offset.
Graham
Offline josh
  •  101 101
Re: H0 AND D0
« Reply #2 on: March 26, 2012, 02:02:13 PM »
So does that mean if i am using tool #2
I should put H2.  D2 on my program
Thanks for the reply
  •  2,785 2,785
Re: H0 AND D0
« Reply #3 on: March 27, 2012, 04:43:35 PM »
That would be the sensible thing to do but you can use any offset with any tool.
